Please Help To Solve This Terrible Bug In Os3.01
39 replies to this topic
#1 hazhiriq
hazhiriq
  • 23 posts
  • Interests:Electrical engineering<br />Communication
    Classpad 300plus
Posted 16 May 2007 - 11:30 PM
in classpad with os 3.01 when the basic seting in deg and decimal , complex when you write
2e^(i45')
it answare 1.050643978+1.701807049i
but it must be 1.414213562+1.414213562i
this bug is only in os3.01 and i check os 3.00 and in os 3.00 it answare right so how can i delete version 3.01 and install version 3 please help me
#2 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 17 May 2007 - 01:54 AM
Works for me. Maybe there is a setting that it is remembering from OS 3.0 that is not compatible with OS 3.01. Try loading OS 3.01 and then resetting all of RAM. If there is data that you need back it up first of course.
#3 hazhiriq
hazhiriq
  • 23 posts
    Classpad 300plus
Posted 17 May 2007 - 06:02 AM
dear gust : i didnot understant what you say would you please describe more!
#4 acid111
acid111
  • 31 posts
    Classpad OS 3.01
Posted 17 May 2007 - 08:55 AM
yes. there is only one way to get the right answer. i think :D
you have to set to rad-mode
then you must write:
2e^(i45?)
then you get the right solution.
or is there another way ??
#5 hazhiriq
hazhiriq
  • 23 posts
    Classpad 300plus
Posted 17 May 2007 - 10:51 AM
I know that when it is in radian mode it answare is right but when you want to use comtopol() function you must use degree mode for taking write answare so when you are in exam u must caculated with radian mode and for finding answare chnge to degree and use comtopol() so i didnot want this i want to back it to OS 3 but i can not
IS THERE any way to reduce the version of os3.01 to os 3.00
i try but it said you can not do this [b]HELP
#6 Kilburn
Kilburn
    Casio Technician
  • PipPipPipPipPipPip
  • 491 posts
  • Interests:Blah
    FX-7500 G
    ClassPad 300
Posted 17 May 2007 - 12:23 PM
NO
Clear ?
And please don't shout.
#7 hazhiriq
hazhiriq
  • 23 posts
    Classpad 300plus
Posted 17 May 2007 - 12:54 PM
So what should i do ; how can i solve this problem ?
I think there is a way to solve this problem what should i do??????????????
i am studing electiral engineering and this bug caused my answare in exam turn to wrong.
#8 hazhiriq
hazhiriq
  • 23 posts
    Classpad 300plus
Posted 17 May 2007 - 01:04 PM
If there is nobody in here to help me to solve this problem (complex error in os 3.01 ) please show me the way that i can report this bug to casio and perhapse they show me the way i can back my os version to 3.00
#9 afshin_electronic
afshin_electronic
  • 50 posts
    casio classpad 300plus
    casia fx-991ms
Posted 17 May 2007 - 06:24 PM
hi there,
dont cry .. I'm studying electrical engineering too & I found the same stupid bug too!! take a lookl at this topic:
http://www.casiocalc...?showtopic=3184
there is no way you can solve this stupid bug ..
the only thing you can do is to use the shift key to create a function PHASE!!
for example
define PH(x)=cos(x)+j*sin(x)
remember to lock the variable!!
and store it in shift key like :
*PH(
then if you will to write 2*exp(45j) instead of pressing 5 keys to write that ... simply write 2*PH(45 using the shift key & pressing 2 keys!!
it raly saves your time!!
remember the mode should be on degree!!
have fun
#10 hazhiriq
hazhiriq
  • 23 posts
    Classpad 300plus
Posted 17 May 2007 - 09:30 PM
I understand what you said but i want to found out how can i back my classpad os version to 3.00.
Thank afshin
#11 The_AFX_Master
The_AFX_Master
  • 519 posts
Posted 19 May 2007 - 04:15 AM
you can't... simply
#12 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 19 May 2007 - 05:25 AM
What happen here???
(!) r e^(i thera?)
is equa to r e^(i thera) in deg mode, and it is equa to r cos(thera(rad)) + i r sin(thera(rad))
(!) r e^(i thera?) is equa to r e^(i pi thera / 180) in rad mode, and it is equa to r cos(thera(deg)) + i r sin(thera(deg))
So:
2e^(i45')
OS 3.01 is right not OS 3.00 :roflol: That's a basic math knowledge.
#13 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 19 May 2007 - 05:41 AM
as you can see in the screenshots above, the default is radian .. so that every value you enter, the os transforms it into radian and then does the calculation!!!
and in os 2.20 it transforms it into radian corectly!!
as a result it gives the correct answer in both degree & radian mode!!
as you can see.. it only does the correct calculation in radian mode..... but in degree mode it makes 65 degrees equal to 66 radians which is wrong and very serious!!!
OS 2.2 is wrong! It isnt a bug, rad values and deg values shouldnt be mixed, that may cause a big wrong in calculate! It's not wrong when OS 3.0 remove the silly transforming and mixing of rad values and deg values!
(I think there shoulg be a warning pops up when you use rad-based funcs in deg mode)
#14 hazhiriq
hazhiriq
  • 23 posts
    Classpad 300plus
Posted 19 May 2007 - 05:59 AM
Dear guest you said the os 3.01 is right but as you said if we write r e^(i thera?) in degree mode it should be answare
r cos(thera(rad)) + i r sin(thera(rad)) but it not right
the right answare is
u can find the right answare in these link:
http://en.wikipedia...._Cartesian_form
http://en.wikipedia....Euler's_formula
http://en.wikipedia....ordinate_system
hence if we try 2e^(i 45?) its answare in degree mode must be 1.414213562+1.414213562i
but if you try this in os 3.01 it said 1.050643978+1.701807049i
and for chech this answare if you use comtopol in degree mode it said 2e^(i 58.31007809?)
i hope u find out what i said
#15 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 19 May 2007 - 11:36 AM
No, Euler's formula: e^(i x)=cos(x) + i sin(x) where x is real number, cos and sin of real number x are cos and sin of x radian. You can ask your teacher for this.
#16 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 19 May 2007 - 11:40 AM
And because OS 3.01's parse the paraters first before parse the function, so in deg mode, 45(deg) is equa to 45
#17 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 19 May 2007 - 11:41 AM
Sorry for many posts but i mean "parameters", not "paraters".
#18 Guest_DegreesBUG_*
Guest_DegreesBUG_*
  • Guests
Posted 19 May 2007 - 04:37 PM
Bottom line, this is a BUG. I don't care who you are or what your thinking is, when I enter 45? I expect it to use this number in degrees, but it doesn't. It strips off the degrees and uses 45 radians in it's calculations. This is WRONG
If I enter 2*cos(45?)+i*2*sin(45?) the ClassPad gets it right, but if I enter 2e^(i*45?) it gets it wrong. I've enter the same damn thing. The answers must be the same!
I'm an electrical engineer and I think in terms of r e^(i theta?). In my book, and the book of every other engineer, Casio is plain worng. Look at all the posts on the topic. I'm not along here. Is Casio saying they don't care about engineers?
#19 Guest_DegreesBUG_*
Guest_DegreesBUG_*
  • Guests
Posted 19 May 2007 - 05:10 PM
What happen here???
(!) r e^(i thera?)
So:
Hey dude, stop with the annoying big red print.
It's not basic math knowledge, it's ignorant programming. When anyone under the sun enters 2e^(45?) there is only one correct answer. Why don't YOU go ask your math teacher what the answer is. Even a moron would be able to figure out on paper that 2e^(45?) = 2*cos(45?) + 2*i sin(45?).
I don't care how the ClassPad is parsing things or how it works internally. I just want the correct answer. 2e^(45?) only has one correct answer (remember, the answer even a moron can figure out).
The ClassPad is blindly trying to decide when to transform degrees into radians and guess what, it got it wrong. It stripped out the degrees and did the calculation is radians. Hey, I'm in degrees mode and I put a degrees symbol on the number. What else can I do? I'm not mixing radians with degrees. I'm trying to do the whole thing in degrees. The ClassPad is mixing them, and it got mixed up.
They probably fixed some other bug in OS 3.01 that converted to radians when it shouldn't Well guys, you broke something else. Stop chasing your tails and keep the degrees with my number.
#20 hazhiriq
hazhiriq
  • 23 posts
    Classpad 300plus
Posted 20 May 2007 - 12:38 AM
tanks dear DegreesBUG
i want to answare that guest :profanity: but you answare him :greengrin: .
some one should fix this problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#21 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 21 May 2007 - 06:42 AM
if you dont like colorful posts, i will use normal :P
r*e^(i* thera (degree) ) != r*cos(thera (degree)) + r*i*sin(thera (degree))
r*e^(i* thera (radian) ) == r*cos(thera (radian)) + r*i*sin(thera (radian))
It must be a "domain error" when use e^(i* thera) in degree mode, cause there is not any ruler when use a degree value in the cap (is it the right word?).
#22 hazhiriq
hazhiriq
  • 23 posts
    Classpad 300plus
Posted 21 May 2007 - 05:29 PM
now this is right answare !
r*e^(i* thera (degree) ) == r*cos(thera (degree)) + r*i*sin(thera (degree))
#23 Guest_Duh_*
Guest_Duh_*
  • Guests
Posted 21 May 2007 - 08:09 PM
You obviously don't understand what you are talking about. I'll try to keep it simple so you can follow along. The following is an identity. Forget about radians or degrees for right now.
r*e^(i* a) == r*cos(a) + r*i*sin(a)
Now make a = b*180/pi. Remember we have an identity. A simple variable substitution doesn't invalidate it. This gives us..
r*e^(i* b*180/pi) == r*cos(b*180/pi) + r*i*sin(b*180/pi)
Wow, will you look at this. This is r*e^(i* theta_degrees) == r*cos(theta_degrees) + r*i*sin(theta_degrees).
You don't know what you are talking. Please go ask your teacher. Otherwise you will continue to embarrass yourself. If you still think you are correct please try to show a proof (you know how to do one of these, don't you?). I'd enjoy seeing this. :P
#24 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 21 May 2007 - 11:27 PM
Writing degree in the cap is only the fast way and shouldnt be used in any public document.
All of you are not sure about your learing :nonono: Dont forget that you are in degree mode :angry:
Posted Image
Check if any site use degree for power calculate (also check maple), I dont think you can find one <_< I dont have much time to talk much here, you should think it carefully before talking! :nod: Bye.
#25 Guest_Serj_*
Guest_Serj_*
  • Guests
Posted 23 May 2007 - 05:35 PM
This bug is really anoying, im studying wave propagation and other stuff dealing with ALOT if complex exponentials, my solution is always to convert everything to degrees... i know, it sucks. So is casio doing anything about this?? :banghead:
#26 Guest_DegreesBUG_*
Guest_DegreesBUG_*
  • Guests
Posted 23 May 2007 - 07:53 PM
Posted Image
TI is broken and conflicts themselves. Domain Error makes no mathematical sense. Enter 2^i on the TI in degree mode and it returns Domain Error. This is wrong.
Enter 2*e^(i 45?) in radians mode. It give you the correct answer. This should not be different then entering it in degrees mode.
Now enter (2 < 45?) when the TI is in rectangular mode. (where < is the special angle mark). The TI gives the correct answer of sqrt(2)+sqrt(2)*i 2*e^(i 45?) is the same thing as (2 < 45?). This is standard syntax for any engineer. Pick up any engineering book. This is not a domain error. This is a valid syntax.
TI may not solve it, but regardless, Casio gets the wrong answer. I think TI returns Domain Error because they do not know how to return the correct answer so they decided not to answe at all.
Please don't use "TI returns domain error" as your argument. This is not a proof and this does not prove anything. Can you give any reason why this should be a domain error?
#27 Guest_hosam_*
Guest_hosam_*
  • Guests
Posted 25 May 2007 - 02:24 PM
hi every body
please i want to install O.S3.0 and ican't find it
please help
#28 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 25 May 2007 - 02:31 PM
YES, if you know the OS offset in the memory.
#29 hazhiriq
hazhiriq
  • 23 posts
    Classpad 300plus
Posted 25 May 2007 - 04:23 PM
Hi "please i want to install O.S3.0 and ican't find it"
You can buy it from casio service in your town or you can buy it online
#30 hazhiriq
hazhiriq
  • 23 posts
    Classpad 300plus
Posted 25 May 2007 - 04:29 PM
Dear gust would you please describe what the meaning of
"if you know the OS offset in the memory"
thanks
#31 SoftCalc
SoftCalc
    Casio Technician
  • 406 posts
    ClassPad 300 , AFX 2.0, HP-48/49/50, TI-89/92/Voyager, HP Expander, etc...
Posted 26 May 2007 - 12:46 AM
Dear gust would you please describe what the meaning of "if you know the OS offset in the memory"
I'm only guessing, but I think this was a joke. If you know the offset of the "1" in memory you can use a hex editor and change it to "0". Presto, instant OS 3.00. :greengrin:
#32 The_AFX_Master
The_AFX_Master
  • 519 posts
Posted 26 May 2007 - 05:34 AM
And you have no need of a microwave :roflol:
#33 Serj
Serj
  • 15 posts
Posted 29 May 2007 - 08:44 AM
Everyone please send a mail to casio asking them to release a patch or something :profanity:
https://secure.casio...upport/contact/
#34 Serj
Serj
  • 15 posts
Posted 30 May 2007 - 08:48 AM
Casio replies with this:
Thank you very much for your letter. You have contacted the European Support Center in Germany.
With regards to your question we can offer you the following information:
By calculation with complex numbers in polar form note the following point.
The ClassPad 300 calculates internally with the angle unit Radian. The angle unit you chosed in setting has no effect on internal calculation. It can only change the display of the result.
If you want to use the angle unit Deg you have to consider this point and do the conversion by yourself in order to get the correct result. For this conversion you have to multiply the term in the power of e with Pi/180. The following exmaple shows how this conversion for the complex numbe 4e^(45i):
Instead 4e^(45i) enter as 4e^(45i*Pi/180) The Pi is the number 3.14...
If you use by your calculations only the angle unit Rad you don't need to pay note to this conversion. There is no change and no conversion if the angle unit Radian is used.
You can also save the conversio factor as a variable like J that has the value J=i*Pi/180. Then you enter the above number as 4e^(45J).
Kind regards,
Khalid Doulali
CASIO Europe GmbH
Bornbarch 10
22848 Norderstedt
Amtsgericht Kiel, HRB 3315
Gesch?ftsf?hrer: Hiroshi Nakamura
I guess it's the best we can do atm. :rolleyes:
#35 hazhiriq
hazhiriq
  • 23 posts
    Classpad 300plus
Posted 30 May 2007 - 04:56 PM
Thanks for Reply me dear seri at first we should do this but i want to send them why this problem is only in OS3.1
#36 PAP
PAP
  • 681 posts
Posted 31 May 2007 - 07:37 AM
For god's sake, this is not a bug nor a problem. Although Casio's customer support is infamous, in this case they replied as expected: just multiply by Pi/180 if you really want to give angles in degrees instead of radians (I can't imagine any good reason to do this). It's more than obvious. ClassPad's CAS has several problems, but this is not one of them.
#37 Serj
Serj
  • 15 posts
Posted 13 June 2007 - 02:05 PM
Well... it is a problem. Imagine doing an exame where everything is asked in degrees, i mean, do u go round asking people how many radians it this or that angle? If so why don't we study radians before degrees in the first place. I don't se people changing the good ol'360 for two times pie! It may seem trivial but if we have to do it hundreds of times in a row ir really doesn't make any sense. If a alphanumerical calculator can do it why can't this behemoth do it?! I didn't spend almost 200euros for something that can make 3d graphs with 20 variables( :roflol: ) but can't convert radians to degrees.
#38 Guest_Tom Lake_*
Guest_Tom Lake_*
  • Guests
Posted 19 July 2007 - 07:35 PM
Try this:
In Radian Mode calculate 2e^(i45')
now switch to Degree mode and use com2pol to convert 1.414...+1.414...i to polar
answer: (2,45')
#39 Guest_Saeed(SMB144)_*
  • Guests
Posted 16 March 2008 - 08:56 AM
Hi, "HazhirIQ"!
There is a simple way to solve this problem and it isn't essential to change your OS really!!
I'm an Electrical engineer,too. My first Operating System was OS2.02 and as you say(and I know) there wasn't that problem on it.
And now I updated my classpad to OS3.03,but I have solved this BUG(If wen can name this a "bug")easily for myself in this way:
first remember this trick: Mode Should be on degree,ALWAYS!!
and now the answer:
define a variable (eg: x) ; then do these on your CP:
>pi/180 :arrow: x ("pi" is:3.1415....-I can't find the symbol of "pi" here)
Then everywhere you selected degree symbol before,you should choose x now!!!
for example:
In classpad OS2.02(and OS3.00 as you say) it was:
>2e^(i45?)
EXE>1.414213562+1.414213562i
An now in classpad OS3.01(3.02,3.03) you should write:
>2e^(i45x)
((Note : The mode is on DEGREE,decimal,algebra))
bYe :rolleyes:
#40 smb144
smb144
    classpad 300+
Posted 16 March 2008 - 09:04 AM
Hi again,"Hazhiriq"
I'm in university now. If you need more help , you can send me an e-mail to send you more instructions and pictures of my procedure.
(My e-mail:smb_144 AT yahoo.com)
